Activity Forums Adobe After Effects Expressions Expression that can read the framerate of a nested comp.
  • Expression that can read the framerate of a nested comp.
    Posted by Hannes Kersting on February 3, 2024 at 10:23 pm
    Hello everyone,
    I am looking for an expression that can read the framerate of a nested composition.
    I have a project in which there are many different specs. Different formats and framerates. To give me an overview of all formats, I have created a composition in which all final animations are embedded as nested comps. This gives me a composition in which I have an overview of all the different formats and the respective designs.
    To further simplify the overview, I have created a text layer for each nested comp, on which there is an expression that recognizes the size of the respective nested comp.
    Unfortunately, I can’t currently find a solution for scanning the framerate as well as the size of the nested comp.
    Does anyone have a solution for me?
    Here is the expression that recognizes the size of the nested comp and displays it on the text layer:
    var input = thisComp.layer(index+1);
    var CompHeight = input.height;
    var CompWidth = input.width;
    var Devider = ” x “;
    var CompSize = CompHeight + Devider + CompWidth;
    [CompSize]
    Thank you in advance for your help !
    Brie Clayton replied 2 years, 6 months ago 3 Members · 3 Replies
  • Dan Ebberts
    February 3, 2024 at 11:03 pm
    You could try something like this:
    (1/input.source.frameDuration).toFixed(2) + " fps"
  • Hannes Kersting
    February 4, 2024 at 7:25 pm
    Works like a charm!
    It was an honor to have been in contact with you.
    Dan: You are the Goat.
  • Brie Clayton
    February 4, 2024 at 10:10 pm
    Thank you, Dan, for this solve!
