Activity › Forums › Adobe After Effects Expressions › Expression Speed ?
  • Dan Ebberts
    May 3, 2006 at 3:55 pm
    If it’s a step change, you could do it like this:
    rate1 = 180; // initial rate (degrees per second)
    rate2 = 360; // final rate
    speedUpTime = 3; // time to start using final rate (seconds)
    if (time < speedUpTime){ rate1*time }else{ rate1*speedUpTime + rate2*(time - speedUpTime) } If you need it to ramp up to the new speed it's a little more complicated, but still doable. Dan
  • Kevin Mcquade
    May 3, 2006 at 4:04 pm
    Cool, I’ll give it a shot!
    And if I did want it too ramp up?
    Kev
  • Sam Moulton
    May 3, 2006 at 5:18 pm
    i’m so lazy that I’d just add a slider and animate that. Dan’s advanced calculations scare me
  • Dan Ebberts
    May 3, 2006 at 6:17 pm
    Something like this should do it:
    rate1 = 90; // initial rate (degrees per second)
    rampStart = 3; // start of ramp final rate (seconds)
    rampEnd = 5; // end of ramp to final rate
    if (time < rampStart){ rate1*time }else if (time < rampEnd){ rate = linear(time,rampStart,rampEnd,rate1,rate2); rate1*rampStart + (rate + rate1)*(time - rampStart)/2 }else{ rate1*rampStart + (rate2 + rate1)*(rampEnd - rampStart)/2 + rate2*(time - rampEnd) } Dan
  • Kevin Mcquade
    May 3, 2006 at 7:28 pm
    I tried animating a slider, but nothing happened. I’ll try to use this expression… but I think I too am about to cry.
    Kev
  • Kevin Mcquade
    May 4, 2006 at 9:18 pm
    Thanks Dan! That expression worked perfectly! Howz about making a layers position change with the beat of a tune? The pick whip puts my object in the corner of the comp!
    Kev
  • Dan Ebberts
    May 5, 2006 at 1:30 pm
    I’m assuming you’ve just pickwhipped your layer’s position to a keyframed slider created by “Convert Audio to Keyframes”.
    To leave the layer in it’s original position and just offset it with the audio, you need to do something like this:
    amplitude = 5;
    temp = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    value + [temp, temp]*amplitude
    Adjust “amplitude” to suit. Here’s another variation that just moves the layer up and down:
    amplitude = 5;
    value – [0, temp]*amplitude
    Etc. – you get the idea.
    Dan
  • Kevin Mcquade
    May 5, 2006 at 1:42 pm
    It just keeps getting better!
    Now… not to push my luck here, but what if I wanted the position of the layer to jump all over the place? I used to do it with Motion Math…
  • Sam Moulton
    May 5, 2006 at 3:54 pm
    that one I can do…
    wiggle(2, 50)
    i think the first number is how many times a second, the second is how much. It may be the other way around….
