Activity Forums Adobe After Effects Expressions Expression: Slider to control the number of vertices along a path
  • Expression: Slider to control the number of vertices along a path
    Posted by Craig Sinclair on January 10, 2023 at 4:51 pm
    I’m trying to design a universal line graph that’s driven by JSON files.
    I’ve made a good working project from a tutorial by Bring your own Laptop. His tutorial is based on a line graph with 12 data points.
    He creates a 12-point path and attaches nulls to each point, then an expression to position each null on his graph according to the data pulled from the JSON files
    In my scenario, I want a graph to be flexible in case I have a data set that has more or fewer data points.
    What I need is to add a slider where I can input the number of data points, which generates a corresponding number of vertices with nulls attached between the first and last vertice of a path.
    Does anyone know a way to go about this or is it a madman’s dream?
    Tomas Bumbulevičius replied 3 years, 7 months ago 3 Members · 4 Replies
  • Dan Ebberts
    January 10, 2023 at 7:25 pm
    If you could format your data as a .csv file, you could import that and drag it into the timeline. When you do that, it generates a data element called “Number of Rows” which could drive the number of points on your graph. I think you could ditch the nulls and have a path expression for your line that would create the path points directly from the data in the .csv. A bit of work and design, but do-able, I think. Then you just replace the .csv file with a new data set and the line should adjust. The details would depend on the specific requirements of your graph.
  • Craig Sinclair
    January 10, 2023 at 8:03 pm
    Thanks I’ll give this a try. Maybe combine both methods
  • Dan Ebberts
    January 10, 2023 at 8:25 pm
    Come back if you have questions.
  • Tomas Bumbulevičius
    January 11, 2023 at 5:42 pm
    Depending on whether you want this to be also animated based on the amount of points in time (faster/slower animation), the idea can reach a bottleneck of complexity real fast.
    But despite of that, try to get rid of nulls as Dan suggested – otherwise solution will be always limited by amount of nulls you create, manually, and not dynamic to the extent you might expect to have.
