Activity › Forums › Adobe After Effects Expressions › Expression request – Line break if “. ” found in source text
  • Expression request – Line break if “. ” found in source text
    Posted by Avinash Ramanath on March 27, 2021 at 1:03 am
    Im looking for a way to break the line if “. ” found in the source text
    For example – line1. line2. line 3 should be printed as
    line1
    line 2
    line3
    Note: I’m getting the source text for this layer from another later. I’m trying this currently
    thisText = thisComp.layer(“Text from here”).text.sourceText.replace(“. “,”/r”);
    Avinash Ramanath replied 5 years, 5 months ago 3 Members · 3 Replies
  • Chris Voelz
    March 27, 2021 at 1:22 am
    This uses a csv to drive the source text, but I’m sure you can use this to get started.
    src = footage(“your footage layer name”).datavalue([1,1])
    src.replace(“. ” , “.” + “\r” + “\r”)
  • Fabrice Leconte
    March 27, 2021 at 12:35 pm
    Simply use:
    text.sourceText.split('. ').join('\r');
  • Avinash Ramanath
    April 6, 2021 at 5:03 am
