Activity Forums Adobe After Effects Expression question: How to get value from Source Text and assign to keyframes?
  • Graham Quince
    June 7, 2021 at 1:53 pm
    Right click on the name of one of your comps and choose Undock. Drag it up so you can see both comp, both layers and both sets of properties. Then you can use the pick whip to link them together.
    Once you’re done, you can drag it back into the comp panel.
