Activity Forums Adobe After Effects Expressions Expression position parent
  • Expression position parent
    Posted by Melissa Franch on December 14, 2015 at 9:52 am
    Hello!
    I want to make an expression linking the position value of an effect on the value of another layer position , but have different methods of value.
    The position value of the auxiliary channel element plugin measured in units , not pixels. How I do?
    Kalleheikki Kannisto replied 10 years, 9 months ago 2 Members · 5 Replies
  • Kalleheikki Kannisto
    December 15, 2015 at 3:26 pm
    The 3D space transformations can get real complex if you are using Element Aux channel animation. I’d suggest figuring out a way to get your additional layer into Element rather than trying to convert between the coordinate systems.
  • Melissa Franch
    December 16, 2015 at 7:20 am
    Thanks for answering!
    The problem is that I need more objects that have the Element groups .
    December 16, 2015 at 8:50 am
    You have 10 aux channel for 5 groups, which makes 50 individually controllable items.
    More to the point, if you want to attach something to something else, use the same Aux channel.
  • Melissa Franch
    December 16, 2015 at 9:03 am
    I use the auxiliary channels but have no position pixels, and need more than 5 items . If they were less than 5 would have no problem because the menu of particles if they have position pixels.
    December 16, 2015 at 11:12 am
    You can animate 50 items separately with a single instance of Element. Can you post a screen shot of what you are trying to do?
