Activity Forums Adobe After Effects expression pickwhip multiple layers at once?
  • expression pickwhip multiple layers at once?
    Posted by Chad Gilmour on April 29, 2008 at 7:34 pm
    Is it possible to select multiple layers, turn on the expression for the position property, and then pickwhip, or some how target the position property on a null object without having to do the pickwhip thing on all 100 layers?
    Devin Gustafson replied 7 years, 2 months ago 4 Members · 4 Replies
  • Darby Edelen
    April 29, 2008 at 8:12 pm
    [chad gilmour] “Is it possible to select multiple layers, turn on the expression for the position property, and then pickwhip, or some how target the position property on a null object without having to do the pickwhip thing on all 100 layers?”
    Yes and no. You can’t pickwhip multiple layers at once, but try using the Edit > Copy Expression Only command and pasting to your multiple layers.
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Ron Coy
    April 30, 2008 at 8:44 pm
    You could also parent layers to a null and try it that way… do a nested comp and parent that to the null.
    many ways to effect multiple layers, but none are ideal in my experience.
  • Chad Gilmour
    April 30, 2008 at 9:57 pm
    Good insight guys thanks, I was aware of the parenting option, looking back I probably should have started with that, but unfortunately the idea that I had involving my question didn’t really work out, but I’ll probably be using this info soon enough. Thanks for the help!
  • Devin Gustafson
    July 1, 2019 at 4:16 am
    This move just saved me so many clicks! Thanks, Darby, I literally created an account to post this response.
