Activity Forums Adobe After Effects expression / parenting
  • expression / parenting
    Posted by Alex Harding on September 14, 2006 at 1:42 pm
    suppose you animate a null object
    then parent another null to this, and add offset animation
    and then use expressions to parent something that can’t be parented in the normal way – ie a corner pin – to this second null
    the corner pin is only affected by the animation stored in the secondary null.
    Is there a way for the expression to access the final resolved coordinates of the second null?
    i hope that makes sense…
    thanks in advance
    alex
    Mylenium replied 19 years, 11 months ago 2 Members · 1 Reply
  • Mylenium
    September 14, 2006 at 2:16 pm
    [alknowshow] “Is there a way for the expression to access the final resolved coordinates of the second null?”
    Sure. Search this forum for “layer space transforms” like toComp(), and you will learn how.
    Mylenium
    [Pour Myl
