Activity Forums Adobe After Effects Expressions Expression Parent of Dynamically Changing Comp
  • Expression Parent of Dynamically Changing Comp
    Posted by Henry Gaunt on June 1, 2016 at 10:07 pm
    Hello.
    Long story short.
    In COMP1 I have a null which dynamically centres depending on the width of 6 text layers in COMP2 via an expression.
    I have a script that automatically imports the text strings for the 6 layers from excel, it duplicates comp for 1 & 2 for each line entry.
    So Comp 2, contains Comp 3. Comp4 contains Comp 5 etc…
    How do I adjust the expression in COMP1 var w1= comp(“COMP2”).layer(“EFFORT”).sourceRectAtTime().width;
    To look at the comp directly below it, rather than a set comp name which fails to update to the new comp during duplication?
    Thank you
    Henry Gaunt replied 10 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
