Activity Forums Adobe After Effects expression or technique for flipping between layers?
  • expression or technique for flipping between layers?
    Posted by Nathan Estabrooks on November 5, 2012 at 5:06 pm
    Apologies for the noob question.
    It’s fersure possible to do what I want to do manually, but I was curious if there’s an expression or technique to accomplish it more elegantly?
    Basically I have two different stickfigure shape layers (a man and a woman). I’ve turned each into 3D shapes and extruded them out.
    I’ve also used a spin expression to continually rotate these stickfigures around a central axis.
    What I want to do, is swap the layers back and forth for 45 seconds so that on one rotation it’s the male stickfigure and then on the next rotation swap in the female stickfigure and so on so forth…
    in other words on each rotation swap in and out between the different shape footage.
    like I said, I know I can do it by doing one or two manual cuts and then copy and pasting them over and over again… but was curious how the pros would do it?
    thanks
    Nate
    Nathan Estabrooks replied 13 years, 10 months ago 3 Members · 4 Replies
  • John Cuevas
    November 5, 2012 at 6:21 pm
    I would make the keyframing the exact same for both layers, just with the opacity offset. Once you create your keyframes for one cycle, then you would apply this expression on opacity and rotation:
    loopOut("cycle")
    ps: I’m not sure what the pros would do, but that’s how I’d handle it.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Darby Edelen
    November 5, 2012 at 6:43 pm
    If the opacity should only be determined based on the layer’s visibility you can use Dan Ebberts’ great expression:
    https://motionscript.com/design-guide/invisible-facing-away.html
    Simply parent one of the layers to the other, rotate the child 180 degrees on the y-axis and apply the expression to both layers’ opacity properties.
    Darby Edelen
  • Nathan Estabrooks
    November 6, 2012 at 6:36 am
    Amazing!
    Thank you Both!
    Both techniques worked like charm.
  • Nathan Estabrooks
    November 6, 2012 at 6:37 am
