Activity Forums Adobe After Effects Expression on Camera Question
  • Expression on Camera Question
    Posted by Pat Bray on August 29, 2008 at 9:21 am
    I have a simple wiggle expression applied to a null, thats parented to a camera, eg: wiggle(0.2,20) just to give the scene a bit more movement, but I was wondering if there was a way of switching this expression off at some point in the animation?
    Any help would be greatly appreciated!
    Nicholas Toth replied 18 years ago 2 Members · 1 Reply
  • Nicholas Toth
    August 29, 2008 at 4:42 pm
    Set your frequency to an expression slider, and then just keyframe it to 0 and it will stop moving. Or you can do it with intensity number. It’ll look like this:
    wiggle(dragpickwhip_to_slider_1,dragpickwhip_to_slider_2)
    Pardon my primitive way of labeling, but delete your digit and drag the pickwhip to the slider, it’ll auto-fill the proper values.
    Then animate the values, you can really do a lot with that effect along the lines of random movement.
