Activity Forums Adobe After Effects Expressions Expression not working on final render
  • Expression not working on final render
    Posted by David Cabestany on April 19, 2013 at 3:43 pm
    I added an expression to the rotation value of a layer. When I ram preview it it plays back fine and I see the expected animation, but when I do a final render, the video looks as if there was no expression applied. I tried baking the keyframes and didn’t work either. When I render the file the cti stops for a moment in the frame where the expression is supposed to start and then continues without generating animation.
    If I disable multiprocessing then the expression doesn’t work at all, not even in ram previews.
    Anyone knows what might be going on?
    Thanks.
    audio=thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider")
    if (audio>=.5)
    {wiggle(5,20)}
    else
    {0}
    David Cabestany replied 13 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
