Activity Forums Adobe After Effects Expressions expression mapping rotation to scale
  • expression mapping rotation to scale
    Posted by Adrian Winter on November 27, 2005 at 1:36 am
    I’m havibng a bit of difficulty trying figure out and expression for an animation I am working on.
    I have set an object to wiggle in scale on the y axis, but I want to set a rotation parameter to the scale value wherein the larger the object is, the faster the object rotates (indefinitiely, on a loop). I was thinking I need to set a loop out expression from 0 to 360 degrees and somehow attatch the speed of the loop to the scale of the object. But I can’t figure out how to do it.
    Any help would be greatly appreciated.
    Thanks in advance,
    -Adrian
    Adrian Winter replied 20 years, 9 months ago 2 Members · 2 Replies
  • Mylenium
    November 27, 2005 at 12:16 pm
    You need some kind of multiplier that you drive using the scale. Thri this:
    scale_Y=thisLayer.scale[1]; //actual Y scale of object
    max_scale=100; //maximum allowed scale of object
    min_scale=0; //minimum allowed scale of object
    rotation_base=20; //constant basic permanent rotation
    rotation_factor_max=5; //maximum multiplier for rotation
    rotation_factor_min=1; //maximum multiplier for rotation
    rotation_factor=linear(scale_Y,min_scale,max_scale,rotation_factor_min, rotation_factor_max); //remaps scale to derive a actual multiplier
    my_rotation=time*rotation_base*rotation_factor; //actual rotation driven by time
    [my_rotation]
    Cheers
    Mylenium
    [Pour Myl
  • Adrian Winter
    November 29, 2005 at 3:01 pm
    Thanks a lot. I’ll give that one a try. Looks like it may be what i need.
    -AW
