Activity › Forums › Adobe After Effects › expression just effecting the x scale
  • expression just effecting the x scale
    Posted by Geoff Lillemon on September 24, 2006 at 8:10 pm
    hi there, is there a way to set an expression to just effect the x scale of a layer and not the x and y
    thanks alot
    geoff
    Geoff Lillemon replied 20 years ago 2 Members · 2 Replies
  • Brian Charles
    September 24, 2006 at 10:17 pm
    newValue = random(100);
    xScale = transform.scale[0];
    yScale = newValue;
    [xScale,yScale]
    Where newValue is what you want the y scale to be.
    The example above uses a random function to produce a value but you could use any method you want here — even an expression slider to keyframe y Scale.
  • Geoff Lillemon
    September 25, 2006 at 1:38 am
    oh thanks alot,
