Activity › Forums › Adobe After Effects Expressions › expression just effecting the x scale
  • Brian Charles
    September 24, 2006 at 10:17 pm
    newValue = random(100);
    xScale = transform.scale[0];
    yScale = newValue;
    [xScale,yScale]
    Where newValue is what you want the y scale to be.
    The example above uses a random function to produce a value but you could use any method you want here — even an expression slider to keyframe y Scale.
  • Geoff Lillemon
    September 25, 2006 at 1:38 am
    oh thanks alot,
  • Trae Sjogren
    September 24, 2013 at 7:22 pm
    I may be 7 years late but you can also use this expression
    The 0 represents X and the 1 represents Y.
    a = input value here;
    [a[0],value[1]]
