Activity › Forums › Adobe After Effects Expressions › Expression: Jump to marker, when counter turns zero
  • Expression: Jump to marker, when counter turns zero
    Posted by Mackie John on January 3, 2019 at 4:05 pm
    I have a marker set to a particular position in timeline. I’m running a counter as follows:
    Now I need to jump to a marker(“End”), when the clocktime turns 0. Can this be done using expression. If yes I need to post it under which property. I’m running the counter under sourceText.
    rate = -1;
    clockStart = parseInt(thisComp.layer(1).text.sourceText.value);
    function padZero(n){
    if (n < 10) return "0" + n else return "" + n
    clockTime = Math.max((clockStart-1*(time-inPoint)),0) ;
    Mackie John replied 7 years, 8 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    January 3, 2019 at 5:56 pm
    Enable time remapping for the layer. Use an expression to set this to the time (property) of the marker “End” if your countdown is 0 and otherwise to value (which is the original pre-expression value).
    Senior Graphic Designer
  • Mackie John
    January 3, 2019 at 7:02 pm
    Thanks Kalleheikki, for the prompt response. Is it possible to show an expression example for the same.
