Activity › Forums › Adobe After Effects Expressions › expression in a layer marker’s comment
Posted by Peter O’connell on August 21, 2008 at 6:23 pmHi, does anyone know if it is possible to have a layer marker’s comment evaluate as an expression so that for example if you type in ‘opacity’ in the comment field it displays as ‘100’
Peteroguekeyframe.com
Dan Ebberts replied 18 years ago 3 Members · 5 Replies -
Peter O’connell
August 22, 2008 at 2:35 amHI Dan, I must be doing something wrong cause when I type that expression in the layer marker’s comment field it doesn’t show up in the timeline as the result, but just as the code I input verbatim.
Help
Pete -
Dan Ebberts
August 22, 2008 at 2:45 amMaybe I misunderstood. That expression goes in the property that you want to have execute the expression in the marker comment. For example, if you put the expression in the layer’s opacity property and put
time * 10
in the first marker comment, you’ll see the opacity increase with time.
Dan
Peter O’connell
August 22, 2008 at 5:08 amHi Dan, well what I was trying to do was get the comment itself (that you see beside the layer marker) to update based on an expression. Maybe that’s not possible?
Pete -
Dan Ebberts
August 22, 2008 at 5:21 amAh, yes. Sorry – you can’t do that. In general, if you can’t keyframe it, you can’t apply an expression to it.
Dan
