Activity Forums Adobe After Effects Expression: How to get value from Source Text and assign to keyframes?
  • Graham Quince
    June 1, 2021 at 7:19 pm
    The Text is a String, and the position values need a number. Fortunately AE uses Javascript, so you can use parseInt() to convert the text to a number:
    temp = parseInt(thisComp.layer("control").text.sourceText);
    [temp, temp]
