Activity Forums Adobe After Effects Expression help please
  • Expression help please
    Posted by Jason Watkins on August 24, 2006 at 9:18 am
    hello,
    i was wondering if it was possible to adapt this script to make the buzz words dissolve into each other over 1/2 seconds or so (adjustable would be better)
    thank you
    buzz_words = ” hopeful, buoyant, life-affirming, lightness, synchronicity, brightness, joy, mood, ambiance, humour, serendipity, up beat, constructive, challenging, optimistic, feeling, joyous celebration, positive, creative, celebration”;
    split_buzz_words_array = buzz_words.split(‘,’);
    buzz_frame_rate = effect(“Buzz Frame Rate”)(1);
    buzz_frame = Math.floor(time * buzz_frame_rate);
    buzz_index = buzz_frame % split_buzz_words_array.length;
    split_buzz_words_array[buzz_index];
    Mylenium replied 20 years, 1 month ago 2 Members · 1 Reply
  • Mylenium
    August 24, 2006 at 3:31 pm
    I have no idea what you are talking about. This expression is specific to the sourceText property and does not work on anything else. To get crossfades, you need at least two layers and animate their opacity (or use a transition effect).
    Mylenium
    [Pour Myl
