Activity Forums Adobe After Effects Expressions Expression help needed
  • Dan Ebberts
    February 10, 2009 at 7:16 pm
    Try this:
    A = thisComp.layer(“a”);
    B = thisComp.layer(“b”);
    a = A.toWorld(A.anchorPoint);
    b = B.toWorld(B.anchorPoint);
    2*b – a
    Dan
  • Jon Smith
    February 10, 2009 at 7:22 pm
    Worked liked a charm. Makes complete sense once you write it out. Thank you so much.
  • Jon Smith
    February 13, 2009 at 4:58 pm
    I now have a new problem. What If I don’t want C to equal the distance betweem A and B. I want to be able to move C around but keep it at the correct angle?
  • Dan Ebberts
    February 13, 2009 at 5:51 pm
    One way would be to add a slider to c and change the expression to this:
    slider = effect(“Slider Control”)(“Slider”);
    b + (b-a)*slider
    You might want to adjust the slider range so that it only goes from 0 to 5 instead of 0 to 100.
    Dan
  • Jon Smith
    February 16, 2009 at 4:26 pm
    Thanks once again Dan Ebberts!
