Activity › Forums › Adobe After Effects › Expression Help Need to distributing text layers in 3D z space
Posted by Matt Stoltz on November 23, 2005 at 9:19 pmhey all anyone know of an easy way to distribute like 20 text layers in 3d z space-evenly
thanks
matt
Steve Roberts replied 20 years, 9 months ago 2 Members · 2 Replies -
Steve Roberts
November 23, 2005 at 9:42 pmTry using this layer index-based expression for each layer’s position:
start = 0;
diff = 0;
[position[0], position[1], start + index*diff]1. create a null with two slider effects. Name one slider “start”, the other”diff”. Place it at the bottom of the stack in the timeline.
2. apply the above expression to one layer
3. Pickwhip each 0 above to one of the sliders
4. test the expression by moving the sliders
5. copy the expression by selecting “position”, then using edit>copy expression only
6. select the rest of the layers and select edit>pasteStart is the position of the first layer in the stack, diff is the gap between. Move the start slider to move the entire group, move the diff slider to change the gap. Change the layer stacking order in the timeline to change stacking order in the group.
You should have something like this for each layer:
start =thisComp.layer(“Null 1”).effect(“start”)(“Slider”);
diff = thisComp.layer(“Null 1”).effect(“diff”)(“Slider”);
[position[0], position[1], start + index*diff]Does that make sense?
Steve -
Steve Roberts
November 24, 2005 at 4:18 amActually, it should be (index-1)*diff :
[position[0], position[1], start +(index-1)*diff]To remove the effect of the diff value from the position of the group. It’s a little cleaner.
Steve
