Activity › Forums › Adobe After Effects Expressions › Expression Help (Lux Spotlight rotation)
  • Expression Help (Lux Spotlight rotation)
    Posted by Matt Fezz on July 7, 2006 at 2:11 am
    Hello there, I have been asked to create some looping graphics for back screens to play in a concert (not a paid job). I have made about 10 so far, but one has me stumped, mainly in the useage of expressions which I know little about.
    Basically the for the look of a full lighting rig with those spotlights that are computer controlled (not sure of their sorrect name.intellegent spotlights?) well basically I have set them up in AE to mimmic an overhead truss setup and applied Lux.
    Now, I have 24 lights and 1 minute of workspace, basically I need the lights to slowly sweep as they would in a real concert (all randomly, but with relatively similar velocity). I figured to do this would be to animate the lights X and Y rotation over an arc of about 180 degrees, I tried using a simple expression, (wiggle(.2,180)) for both rotation properties, and this looked OK, except the velocity was not constant. I am basically going for the look of a constant ‘sweep’ from the lights.
    Now I know its not that cool to simply ask for work to be done for me, but I am sure most of you would have a better grasp of expressions than my very basic knowledge. Could you recommend at least a starting point or an expression that would achieve the look I am going for? If any of you have any lighting experience and have programed those lights perhaps you would know an algorithm?
    Thanks, I really appreciate it guys
    Matt Fezz replied 20 years, 2 months ago 2 Members · 2 Replies
  • Mylenium
    July 7, 2006 at 5:57 am
    I think you are using the wrong approach for this. You should randomize the timing, not the animation itself. What I would do is to create a reference spotlight. Animate it one cycle, then use loopOut(“cycle”) to continue that animation infinitely. On your other lights use something like that:
    seedRandom(index,true);
    original=thisComp.layer(“Reference Light”).rotationX;
    //timing variation offset in seconds
    time_min=-10;
    time_max=10;
    time_rand=random(time_min,time_max);
    //timing variation multiplier
    time_mult_min=-10;
    time_mult_max=10;
    time_mult=random(time_min,time_max);
    //angle variation
    angle_min=-90;
    angle_max=90;
    angle_rand=random(angle_min,angle_max);
    //rotation value of reference mapped to new time
    angle_time=original.valueAtTime(time+time_rand*time_mult);
    //new rotation
    angle_final=angle_time+angle_rand;
    [angle_final]
    By playing with the values you should be able to control every parameter pretter easily. I would create some sliders on a dummy layer, so you can vary all your parameters easily once you have your expression applied and cloned your lights into an array.
    Mylenium
    [Pour Myl
  • Matt Fezz
    July 7, 2006 at 7:14 am
    Thanks alot, i ended up using loopOut(type = “cycle) after I keyframed one rotation, then just duplicated the animation and changed some valvues manually.
    I got the result I was looking for, thanks again
