Activity › Forums › Adobe After Effects › Expression help: If X = 1 then do the following…
  • Expression help: If X = 1 then do the following…
    Posted by Aharon Rabinowitz on December 6, 2006 at 10:42 pm
    Hey there-
    I am working on a tutorial on expression controls but the control called Checkbox Control is hard to demonstrate practically. It uses a binary value system of off or on, which is really 0 or 1. Now there are some effects and propertues that use this sytem (such as the property in the fractal noise effect called invert), but animating that propery isn’t a common thing for people to do.
    Since the system uses 0 or 1, I was thinking of demonstrating an expression like – If X = 0 then do this, if X = 1 do this.
    So how do I write an If then Statement?
    To set up x properly, I know that I need to write this
    x = thisComp.layer(“Null 2”).effect(“Checkbox Control”)(“Checkbox”);
    after that, I’m lost. I can figure out how to write the part about what should happen, I just don;t know how to write if X = 0 do this, if X = 1 do that.
    Thanks.
    Aharon
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
    Aharon Rabinowitz replied 19 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 6, 2006 at 11:14 pm
    Here’s a simple checkbox for Opacity expression that should get you started:
    if (x == 1){
    100;
    }else{
    0;
    Dan
  • Aharon Rabinowitz
    December 6, 2006 at 11:25 pm
    Thanks! Very Helpful.
    Aharon Rabinowitz
