Activity Forums Adobe After Effects Expression help.
  • Expression help.
    Posted by Cwolfe on March 3, 2006 at 8:49 pm
    I’ve got a client who needs to do a sort of auto-lip-flap, with an effect happening in psync with VO. I’ve got it working a little to well using the Audio to keyframes assist.
    Here’s the problem, he wants the effect to happen “a little less often.” If I can limit the effect so it occurs only when the audio goes over a certain amplitude it would do the trick. After it passes this point it would then need to fade up and out in a linear manner relative to the amplitude of the audio.
    any ideas?
    -Chris
    Cwolfe replied 20 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
