Activity Forums Adobe After Effects Expressions expression help
  • Posted by Khaos119 on August 11, 2006 at 3:03 am
    i have forgotten how to make my text expression only scale on “x” to my audio. i know you have to change something on the [temp,temp] line… can anyone help?
    Thanks!!
    Khaos119 replied 20 years ago 2 Members · 3 Replies
  • Curious Turtle
    August 11, 2006 at 5:30 am
    Expland the expression line down, and you’ll see two lines. The [temp,temp] is an array, the first “temp”, refers to X and the second one affects Y. So just change the second value to 100 or whatever value you like.
    The “temp” is stuck in there automatically when you pickwhip, so it might be a bit easier to change that to a name that you can remember when you come back to it.
    If you want to keyframe the Y value later, then highlight the second array and pickwhip the Y Scale on your layer. Or type “transfor.scale[1], whichever you find easier.
    HTH
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • Curious Turtle
    August 11, 2006 at 5:31 am
    Missed off an “m”, so that last line should read “transform.scale[1]”.
    Oops.
  • Khaos119
    August 12, 2006 at 11:48 pm
    thank you!!!
