Activity Forums Adobe After Effects Expression help
  • Expression help
    Posted by Dan Schaffner on April 10, 2006 at 3:04 pm
    I’m using an expression that links the scale to audio keyframes. How do I control the expression so that it won’t scale past the layers original size?
    I just used the pick whip to create the expression.
    Ryan Hill replied 20 years, 5 months ago 2 Members · 1 Reply
  • Ryan Hill
    April 10, 2006 at 6:25 pm
    How high is the scale going now?
    I don’t remember what scale “convert audio” normally uses. But find the highest that your values are going right now, then make your scale expression into
    (current expression)/highest value*100
    Or if you meant to apply a ceiling instead of scaling the whole thing, use
    Math.max(current expression,100)
