Activity Forums Adobe After Effects Expression Help
  • Expression Help
    Posted by Eric Goldstein on April 15, 2009 at 5:34 pm
    I’m using this expression:
    thisComp.layer(“Main Hinge”).transform.position[2]
    to rotate a gear based on x position of another layer.
    It works, but I want to reverse the direction of the rotation
    and gear it down. Would someone suggest code I could use to do
    this?
    Eric
    Eric Goldstein replied 17 years, 4 months ago 2 Members · 2 Replies
  • Kevin Camp
    April 15, 2009 at 5:50 pm
    adding a minus to the beginning of the expression should do the trick:
    -thisComp.layer(“Main Hinge”).transform.position[2]
    or you could do:
    value – thisComp.layer(“Main Hinge”).transform.position[2]
    to give you a bit of control for the starting value of the rotation…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Eric Goldstein
    April 15, 2009 at 5:55 pm
    Thanks,Kevin
    I just hit on this before I read your post:
    ((thisComp.layer(“Main Hinge”).transform.position[2])*-1)
    but a negative sign before the expression is nicer.
    Eric
    Eric Goldstein
    Giraffe Film Company
    Los Angeles
    eric@giraffefilm.com
