Activity Forums Adobe After Effects Expressions Expression- getting each text height when there are 3 line text in the text box
  • Expression- getting each text height when there are 3 line text in the text box
    Posted by Aurora Wang on January 30, 2023 at 6:48 pm
    I am looking for an expression that can get each line text’s height when there are several lines in the text box. It would be very useful if I create a responsive mask box for each line.
    Julian Chojnacki replied 3 years, 7 months ago 2 Members · 3 Replies
  • Julian Chojnacki
    January 30, 2023 at 7:39 pm
    Hi, you could either take fontSize*.75 + leading, or the sourceRect height of your text layer divided by the number of lines. So:
    const { fontSize, leading } = thisComp.layer("Text").text.sourceText.style;
    const lineHeight = fontSize*.75 + leading;
    Or
    const numLines = thisComp.layer("Text").text.sourceText.split('\r').length;
    const lineHeight = thisComp.layer("Text").sourceRectAtTime().height/numLines;
  • Aurora Wang
    January 30, 2023 at 8:56 pm
    Hey Julian, Thank you for your expression!
    – The first one doesn’t work if I change the text from 3 lines to 2 lines. (Attached the images) Please lmk if I am wrong.
    – The second one works great! If you have time, would you please explain the “const numLines thisComp.layer(“Text”).text.sourceText.split(‘\r’).length;” a little bit?
    I only know that using “split(‘\r’)” can return the text to the next line. And “length” in text expression is the length of all characters. I have no idea when you combine them, you will get the number of lines. Wow!
  • Julian Chojnacki
    February 5, 2023 at 2:10 pm
    Hi Aurora, you’re right – the first code needs tweaking. Check out this great reference that dives a bit deeper into getting actual text heights:
    https://motiondeveloper.com/blog/dealing-with-descenders
    Regarding split(‘\r’).length, split first breaks up the text into an array using the carriage return as a separator, then length returns the length of that array.
