Activity › Forums › Adobe After Effects › Expression for Timecode Generator, so I don’t have to render for hours???
Posted by Daniel Elder on October 17, 2006 at 10:53 pmThat’s all I wanted to know, is if there is a time code generated expression that reads it with 01:00:00:00 timecode, thanks
Dan
Daniel Elder
Associate Producer
http://www.luminair.comDaniel Elder replied 19 years, 10 months ago 2 Members · 5 Replies -
Dan Ebberts
October 18, 2006 at 2:42 amJust apply this expression to the Source Text of a text layer:
timeToTimecode(3600 + time)
That should do it.
Dan
Daniel Elder
October 18, 2006 at 1:47 pm -
Daniel Elder
October 18, 2006 at 2:22 pmHey Dan,
It seems that this doesn’t do much as far as render time, is it a big difference between the expression and the generator effect?
Dan
Daniel Elder
Associate Producer
http://www.luminair.com -
Dan Ebberts
October 18, 2006 at 4:08 pmProbably not. Maybe I don’t understand your issue. It sounds like you want to apply a time code without having to render, but I’m guessing that’s not it.
Dan
Daniel Elder
October 18, 2006 at 5:14 pmNo,
I plan to render, I was just wondering if the Expression had any benefits over the generator effect as to limiting the size of the render or limiting the time of the render, but it doesn’t appear to.
Dan
Daniel Elder
Associate Producer
