Activity Forums Adobe After Effects Expression for Mirroring a value but setting different max and min parameters
  • Expression for Mirroring a value but setting different max and min parameters
    Posted by Brian Lee on November 23, 2015 at 6:50 pm
    I’m trying to mirror the Blur Radius of a camera lens blur effect to the opacity of the text layer of which it is applied. Pickwhipping the blur to the opacity is easy enough however when the opacity=0% I want the blur radius to be “11” and when the opacity=100% i want the blur effect to be “2”. So for instance if I animate the opacity property to go from 0%-100% i want the blur radius to decrease from 11 to 2 at the same rate.
    Is there as an expression that I can apply that will allow me to do this?
    Brian Lee replied 10 years, 9 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    November 24, 2015 at 7:19 am
    For lens Blur Radius:
    linear(transform.opacity, 0,100,11,2)
    this takes the opacity value and linearly interpolates it from 0-to-100 range to 11-to-2 range.
  • Brian Lee
    November 24, 2015 at 4:53 pm
    Thank you so much! That worked perfectly and will now be using this very powerful function so much more in my work.
    Brian
