Activity Forums Adobe After Effects Expressions Expression for mask mode selection
  • Expression for mask mode selection
    Posted by Roland R. kahlenberg on March 17, 2026 at 12:57 pm
    Greetings CowPokes – is there a way to get the mask mode selection via Expression?
    maskModes exists for the scripting API but there doesn’t seem to be one for Expressions. I tried the propertyGroup() way but either it’s not possible or I’m not doing it right.
    Any help will be greatly appreciated.
    Bestest!
    Roland R. kahlenberg replied 5 months ago 2 Members · 4 Replies
  • Dan Ebberts
    March 17, 2026 at 4:30 pm
    I don’t know of a way to access the mask mode from an expression. If you find out that there is a way, please come back and post it!
  • Roland R. kahlenberg
    March 19, 2026 at 1:04 am
    IF I get back to it – moved on to other matters. My thoughts – since there isn’t an Expression to access it then the propertyGroup way would be the only option and you’re expert in this area. I’ll have to think of a roundabout way to do it OR file it away as “Unimportant”. 🙂
  • Dan Ebberts
    March 19, 2026 at 1:08 am
    Yeah, I sniffed around for a while using propterGroup() but I didn’t get anywhere. I don’t think it’s there, but I’d be happy to be proven wrong.
    March 19, 2026 at 3:45 am
    It’s the same issue with getting a Shape Layer’s mode – the pattern with the issue is when a Drop Menu occurs on the same and first line of the propertyGroup(). And the 3D Meshes too – the Mesh Options property.
