Activity Forums Adobe After Effects Expressions expression for makeing things faster gradually?
  • expression for makeing things faster gradually?
    Posted by Walkingduck on May 12, 2005 at 4:26 pm
    Hello folks?
    Can someone teach me how to make things go faster with expression ?
    I’m trying to make a timer with a needle that goes faster toward to 0 from 30.
    I used the Loop out with position, but it just moves with the same speed, so I wanted to make it go faster as the second goes down to 0.
    Can I get some help?
    Walkingduck replied 21 years, 4 months ago 2 Members · 3 Replies
  • Walkingduck
    May 12, 2005 at 4:30 pm
    and rotation.
    it’s like the needle moving left and right.
  • Steve Roberts
    May 12, 2005 at 5:11 pm
    It sounds as if you need to adjust your keyframes from linear to bezier in the timeline. I think it’s in the help under “fine-tuning animation”.
    The velocity curve should start flat, then gradually slope up.
    Steve
  • Walkingduck
    May 12, 2005 at 10:33 pm
    So, What I did insted playing with expression was.
    I add the loop out on the layer and made that layer in pre-comp and then, time remap the pre-comp.
    It waoked out with the way I wanted.
    Thanks.
