Activity › Forums › Adobe After Effects Expressions › Expression for in out opacity change
  • Expression for in out opacity change
    Posted by Aharon Rabinowitz on December 10, 2006 at 11:38 pm
    I looked around but couldn’t find a post about this – has anyone written an expression that makes layers fade up and down based on thier in/out points? This would be a great tool for quick edits with little or no work.
    I usually do 15 frame fade ups and downs, and if the trimming changes I have to remember to account for that. I’ve got to get better at expressions…
    Thanks.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
    Aharon Rabinowitz replied 19 years, 9 months ago 5 Members · 10 Replies
  • 10 Replies
  • Andrew Kramer
    December 11, 2006 at 12:33 am
    Harry Frank made this nice script that works well:
    transition = 40
    tSecs = transition / ( 1 / thisComp.frameDuration);
    iStart = thisLayer.inPoint
    oStart = iStart + tSecs;
    oEnd = thisLayer.outPoint
    iEnd= oEnd- tSecs;
    halfPoint = (iEnd – iStart) / 2;
    if (time < halfPoint){ linear(time, iStart, oStart, 0, 100) }else{ linear(time, iEnd, oEnd, 100, 0) } Just paste it into the opacity expression and change the transition amount as needed. Thanks Harry! Best, Andrew Kramer
  • Mike Clasby
    December 11, 2006 at 12:42 am
    Here’s a post, with a Dan expression (second post), that does what you want I think.
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=877561
    Just change the expression to:
    fadeInTime = .5; // fade in time (seconds)
    fadeOutTime = .5;
    Math.min(linear(time,inPoint,inPoint + fadeInTime,0,100),linear(time,outPoint – fadeOutTime,outPoint,100,0))
  • Aharon Rabinowitz
    December 11, 2006 at 4:58 am
    Thank! Both of these work great. What if you wanted to only fade in or only fade out. I tried futzing around with this stuff, but couldn’t figure what parts had to go.
    Man, I love this forum.
    Aharon Rabinowitz
  • Andrew Kramer
    December 11, 2006 at 5:21 am
    With Dan’s script I would just set the fadeout time to 0 or whichever. Nice script btw.
  • Andrew Kramer
    December 11, 2006 at 5:26 am
    Oh and then if you want to only fade out, change the first 0 in the 3rd line of code to 100 so that no matter what the fadeInTime is, it will remap the value to 100-100 so no change, just opaque.
    Math.min(linear(time,inPoint,inPoint + fadeInTime,100,100),linear(time,outPoint – fadeOutTime,outPoint,100,0))
  • Colin Braley
    December 11, 2006 at 5:28 am
    Fade in only…
    fadeTime = 10;//frames
    linear( time, inPoint, inPoint + framesToTime( fadeTime ), 0 , 100);
    Fade out only…
    linear( time, outPoint – framesToTime( fadeTime ), outPoint, 100 , 0);
    or if you want to be able to do fade in, fade out, or both within one expression just change the values of fadeIn and fadeOut in the following expression…
    fadeTime = 10; //frames
    fadeIn = true;
    fadeOut = false;
    if ( ! fadeIn && ! fadeOut )
    100
    }else if ( fadeIn && ! fadeOut) {
    }else if ( fadeOut && ! fadeIn ) {
    else{
    if( time > this.inPoint + framesToTime( fadeTime ) )
    else
    Enjoy
    ~Colin
  • Mike Clasby
    Yeah, with Dan’s, 0 for FadeOutTime seems to work, but 0 for FadeInTime leaves the layer at 0% opacity the whole clip, but 0.01 gives 0% at the inpoint, then to 100% at the second frame into the clip, so it’s off by one frame. Maybe Dan has a fix.
  • Mike Clasby
    December 11, 2006 at 5:30 am
    Thanks.
  • Tony Kloiber
    December 11, 2006 at 3:53 pm
    Dan gave me that expression a couple years ago when I need to animate several hundred still files. Man did it save me some time on that project.
    Thank you again Dan.
    TonyTony
  • Aharon Rabinowitz
    December 11, 2006 at 10:08 pm
    That’s what I love about After Effects – also known as the program that asks: how many ways can you skin a cat?*
    Thanks folks!
    Aharon
    *Please note that the writer of this post does not support the skinning of actual cats.
    Aharon Rabinowitz
