Activity Forums Adobe After Effects Expressions expression for color control – frame hold – slider number?
  • expression for color control – frame hold – slider number?
    Posted by Bart Stevens on May 19, 2013 at 5:20 pm
    I’m using a great expression from created by Filip Vandueren
    to create a random fill effect via color control expressions.
    Currently the colors change every frame, what I would like to have a is a slider that determines how many frames the colors hold. 1 would be like it currently is (updating every frame), 2 it would hold for 2 frames, etc…
    Not exactly sure how to go about this,
    Here is the expression I’m using for the random fill:
    l=thisComp.layer(“Colors”);
    i=1;
    colors=[];
    try {
    while(l.effect(i)) {
    if (l.effect(i)(1).name==”Color”) {
    colors.push(l.effect(i)(1).value);
    i++;
    } catch (e) {}
    if (colors.length) {
    r=Math.floor(random(colors.length));
    colors[r];
    } else {
    value;
    Thanks for the help
    Bart Stevens replied 13 years, 3 months ago 2 Members · 4 Replies
  • Dan Ebberts
    May 19, 2013 at 6:44 pm
    Adding this to the beginning or your expression should work:
    s=Math.max(Math.round(effect(“Slider Control”)(“Slider”)),1);
    f=timeToFrames(time);
    seed = Math.floor(f/s);
    seedRandom(seed,true);
    Dan
  • Bart Stevens
    May 20, 2013 at 4:17 pm
    Thanks Dan,
    This works great if my slider is on the same layer, but I have my slider on another layer called “Colors”.
    I tried modifying your expression, but the language is still off.
    Any ideas why it’s not seeing the slider on the master layer?
    s = thisComp.layer("Colors").effect("Slider Control")("Slider").value;
    s=Math.max(Math.round(effect("Slider Control")("Slider")),1);
  • Dan Ebberts
    May 20, 2013 at 4:28 pm
    Try it this way:
    slider = thisComp.layer(“Colors”).effect(“Slider Control”)(“Slider”).value;
    s=Math.max(Math.round(slider),1);
    Dan
  • Bart Stevens
    May 20, 2013 at 5:23 pm
    Great, thanks again Dan
