Activity Forums Adobe After Effects Expression for bringing a spinning 2D shield onto screen from zspace.
  • Expression for bringing a spinning 2D shield onto screen from zspace.
    Posted by Christian Vilderman on December 28, 2015 at 1:40 pm
    Hi
    I have a shield psd and would like to bring the shield spinning on its X axsis into frame and land facing camera. The direction the shield will come from will be the Z axis.
    Also is there way of making it look more 3D whilst spinning?
    Any expressions or methods for doing this realistically?
    Cheers
    Chris Evans replied 10 years, 8 months ago 2 Members · 1 Reply
  • Chris Evans
    December 28, 2015 at 4:38 pm
    You could just keyframe the rotation and position. For example, if it takes 1 second for the shield to animate on, go forward one second, set a keyframe for position and rotation (not orientation) then go back to the beginning, drag the shield shape way back in z-space and set the x rotation to something like -10x and adjust that for how fast you want it to go.
    Unless I’m misunderstanding you, you don’t need an expression. Though you could use something like time*50 if you wanted it to keep spinning forever.
