Activity Forums Adobe After Effects Expressions Expression for Alexa footage. Example expression included.
  • Expression for Alexa footage. Example expression included.
    Posted by Simon Björk on September 12, 2011 at 11:10 am
    At the moment there isn’t a simple way to do a logC to linear color conversion of Arri Alexa footage in After Effects. The LUTs provided by Arri doesn’t seem to work for this. In Nuke, you just use a simple curve created be this expression:
    AlexaV3LogC =
    (x > 0.1496582 ? pow(10.0, (x – 0.385537) / 0.2471896) : x / 0.9661776 – 0.04378604) * 0.18 – 0.00937677
    As I’m no expert on these type of expressions, I’m unsure how to convert it to use with a levels or a curve effect in AE. All I know is that it’s a if/else statement where ? is “then” and the : means “else”.
    Anyone?
    Dan Ebberts
    replied 15 years ago
    2 Members · 3 Replies
  • Dan Ebberts
    September 12, 2011 at 3:21 pm
    I don’t know that much about LUTs, but is that formula for a pixel-by-pixel manipulation of luminance? If so, I would think you could do it with a PixelBender effect. Convert RGB to HSL, run luminance through the formula, then HSL to RGB. Something like that.
    Dan
  • Simon Björk
    September 14, 2011 at 8:11 am
    Thanks for your reply Dan, I will try to do some more research on the subject. Out of curiosity, how come you don’t think it’s possible with expressions?
  • Dan Ebberts
    September 14, 2011 at 5:57 pm
    My assumption is that it needs pixel-by-pixel processing, which you can’t do (at least in a practical way) with expressions. Of course, I could be completely wrong. I mean, can you manually set up a Levels effect to do this conversion? I guess if you could, you could just save that as a preset.
    Dan
