Activity Forums Adobe After Effects expression for 3D orientation
  • expression for 3D orientation
    Posted by Ryan Chan on July 6, 2006 at 7:04 pm
    hello guys, i have read the case study from Dan Ebberts for 2D orientation, it is very useful. and did anybody know if we can also be able to get the information/data from 3D orientation? with and without considering the camera’s position(camera work). thanks
    Dan Ebberts
    replied 20 years, 2 months ago
    4 Members · 6 Replies
  • Mylenium
    July 6, 2006 at 7:51 pm
    Use the lookAt() method. It does basically the same as orientation parameters.
    Mylenium
    [Pour Myl
  • Ryan Chan
    July 6, 2006 at 8:29 pm
    sorry, what i mean is, can i extract the value from the 3D Auto orientation, so i can use it for other reason(layer). thanks
  • Dan Ebberts
    July 6, 2006 at 8:53 pm
    Try this:
    L = this_comp.layer(“Layer 1”);
    s = L.scale/100;
    u = L.to_world_vec([s[0],0,0]);
    v = L.to_world_vec([0,s[1],0]);
    w = L.to_world_vec([0,0,s[2]]);
    sinb = clamp(w[0],-1,1);
    b = Math.asin(sinb/this_comp.pixel_aspect);
    cosb = Math.cos(b);
    if (Math.abs(cosb) > .0005){
    c = -Math.atan2(v[0],u[0]);
    a = -Math.atan2(w[1],w[2]);
    }else{
    a = Math.atan2(u[1],v[1]);
    c = 0;
    [radians_to_degrees(a),radians_to_degrees(b),radians_to_degrees(c)]
    Substitute your layer for “Layer 1”.
    Dan
  • Ryan Chan
    July 6, 2006 at 9:16 pm
    thanks so much, Dan
  • Filip Vandueren
    July 7, 2006 at 1:11 am
    Hi Dan,
    I can’t test this for the moment,
    but would this expression sum up all the rotations for e.g.
    a camera that is Auto-oriented + keyframed for rotation + keyframed for orientation ?
    if so: brilliant stuff, just what I needed for a problem I was working on 😎
    on a related note: do you think it is feasible in Javascript to convert an After Effects style 3D Euler rotation to a VRML-style axis+angle rotation ?
  • Dan Ebberts
    July 7, 2006 at 1:51 am
    It seems to. Except possibly in a gimbal lock situation.
    Thanks! 🙂
    I’m not that familiar with VRML, but it seems like it should just be a matter of cooking up the right transform.
    Dan
