Activity › Forums › Adobe After Effects Expressions › expression for 3D orientation
Posted by Ryan Chan on July 6, 2006 at 7:04 pmhello guys, i have read the case study from Dan Ebberts for 2D orientation, it is very useful. and did anybody know if we can also be able to get the information/data from 3D orientation? with and without considering the camera’s position(camera work). thanks
Dan Ebbertsreplied 20 years, 2 months ago 4 Members · 6 Replies
Mylenium
July 6, 2006 at 7:51 pmUse the lookAt() method. It does basically the same as orientation parameters.
Mylenium
[Pour Myl
Ryan Chan
July 6, 2006 at 8:29 pmsorry, what i mean is, can i extract the value from the 3D Auto orientation, so i can use it for other reason(layer). thanks
Dan Ebberts
July 6, 2006 at 8:53 pmTry this:
L = this_comp.layer(“Layer 1”);
s = L.scale/100;
u = L.to_world_vec([s[0],0,0]);
v = L.to_world_vec([0,s[1],0]);
w = L.to_world_vec([0,0,s[2]]);
sinb = clamp(w[0],-1,1);
b = Math.asin(sinb/this_comp.pixel_aspect);
cosb = Math.cos(b);
if (Math.abs(cosb) > .0005){
c = -Math.atan2(v[0],u[0]);
a = -Math.atan2(w[1],w[2]);
}else{
a = Math.atan2(u[1],v[1]);
c = 0;
[radians_to_degrees(a),radians_to_degrees(b),radians_to_degrees(c)]Substitute your layer for “Layer 1”.
Dan
Filip Vandueren
July 7, 2006 at 1:11 amHi Dan,
I can’t test this for the moment,
but would this expression sum up all the rotations for e.g.
a camera that is Auto-oriented + keyframed for rotation + keyframed for orientation ?if so: brilliant stuff, just what I needed for a problem I was working on 😎
on a related note: do you think it is feasible in Javascript to convert an After Effects style 3D Euler rotation to a VRML-style axis+angle rotation ?
Dan Ebberts
July 7, 2006 at 1:51 am>would this expression sum up all the rotations
It seems to. Except possibly in a gimbal lock situation.
Thanks! 🙂
I’m not that familiar with VRML, but it seems like it should just be a matter of cooking up the right transform.
Dan
