Activity Forums Adobe After Effects Expressions Expression Error!!
  • Expression Error!!
    Posted by Naveen Prasanth on November 15, 2009 at 2:00 pm
    I was working with AE last night with an expression,the purpose of this expression,was simply for the background layer to have the opposite color of a shape layer.First, I hooked up three slider control effects to a null and renamed them each as red,green,blue.Then i made the expression in the shape layer’s fill property as,
    red = thisComp.layer(“Null 1”).effect(“red”)(“Slider”);
    green = thisComp.layer(“Null 1”).effect(“green”)(“Slider”);
    blue = thisComp.layer(“Null 1”).effect(“blue”)(“Slider”);
    alpha = 1;
    [red,green,blue,alpha]
    This worked out fine, i also added the wiggle expression to the sliders and everything went well until when i wanted the background layer to have the opposite color the shape layer and so here is the expression
    alpha = 1;
    hsl = rgbToHsl([red,green,blue,alpha)];
    hsl[0] += .5;
    if (hsl[0]>1) (hsl[0] -= 1);
    rgb = hslToRgb(hsl);
    rgb
    Naveen Prasanth replied 16 years, 9 months ago 2 Members · 2 Replies
  • Xinlai Ni
    November 15, 2009 at 4:22 pm
    Is this because you have a ([… )] mismatch in the rgtToHsl line?
    Xinlai Ni
    Software Engineer, Google Inc.
  • Naveen Prasanth
    November 16, 2009 at 2:54 am
    Thank u Xilnai didn’t notice that bugger! I will try rectifying it!!
