Activity Forums Adobe After Effects Expressions Expression error: unclosed token, have no idea what it is
  • Expression error: unclosed token, have no idea what it is
    Posted by David Cabestany on August 9, 2017 at 10:46 pm
    I’m getting the following error:
    Unclosed token
    when applying the expression below, have no idea what it means and can’t seem to fix it, can anyone help?
    Thanks in advance.
    t=time;
    if
    (t>=5.75 && <6.2)
    random(-3,3)
    else
    0
    Ben Robinson replied 8 years, 10 months ago 2 Members · 4 Replies
  • David Cabestany
    August 9, 2017 at 11:01 pm
    Nevermind, I know why.
  • Ben Robinson
    November 13, 2017 at 2:39 pm
    What was the answer to this? I’m getting a similar error, but can’t work out why…?
  • David Cabestany
    November 13, 2017 at 3:10 pm
    You need to specify the property or variable in the conditional for both the first and second statements (I’m not sure if those are the names of the parts of the expression), so in my example instead of
    (t<=5.75 && <6.2)
    it should be
    (t<=5.75 && t<6.2)
    Hope this helps.
    D.
  • Ben Robinson
    November 13, 2017 at 9:01 pm
    Awesome! Thank you. I don’t think I’ve used the && statement before–so obviously wasn’t aware of the syntax.
    Thanks for your help.
