Activity Forums Adobe After Effects Expressions Expression error trying to rotate z using index
  • Expression error trying to rotate z using index
    Posted by Jack Phillips on April 10, 2014 at 11:58 pm
    I’ve been trying to figure out why I’m getting an error but I’m stumped. I’m trying to use the index to rotate a 3D layer’s z-rotation, but I get a “Class ‘global’ has no property or method named ‘t'” error. BTW, the expression works as expected on the first 5 layers in the comp.
    Any help would be greatly appreciated.
    Jack
    num=(index/5 % 1);
    if (num==.2) t=-60;
    if (num==.4) t=60;
    if (num==.6) t=-120;
    if (num==.8) t=120;
    if (num==.0) t=0;
    [t]
    Jack Phillips replied 12 years, 4 months ago 3 Members · 4 Replies
  • James Peres
    April 11, 2014 at 2:05 am
    Hi, not sure what you are trying to do exactly, but 10/5 % 1 would be 0.02, so I don’t think it will work the way you want.
    Also, I would personally put t=0 before everything, and then put the t=[whatever] in braces, then not put t in brackets. There may be some quick shortcuts I’m not sure about but I just stick to the basic syntax.
    James
    Mac Pro 4,1 Quad Core 2.66
  • Jack Phillips
    April 11, 2014 at 11:36 am
    Hi James,
    Thanks for your response. Unfortunately, changing the code did not change the result (updated code included).
    The statement to get the “num” variable works as expected (btw, (10/5 % 1) will be 0 as the remainder of (10 divided by 5) divided by 1 is 0). The problem seems to be with the conditional statements. And the error doesn’t appear until the sixth layer in the comp upwards.
    Jack
    num=(index/5 % 1);
    t = 0;
    if (num==.2) {
    t=-60
    if (num==.4) {
    t=60
    if (num==.6){
    t=-120
    if (num==.8){
    t=120
    t
  • Xavier Gomez
    April 11, 2014 at 3:50 pm
    You can try with a switch over index%5 (equivalent, but simpler than index/5 % 1):
    switch (index%5){
    case 1 : t =-60; break;
    case 2 : t = 60; break;
    case 3 : t = -120; break;
    case 4 : t = 120; break;
    default : t = 0;
    t;
    Xavier
    Edit : It is quite risky to compare non integral numbers…
    You can try this: open the javascript editor (File>Scripts>Open Scrip Editor), type the line:
    6/5 % 1;
    press ‘play’ (top right area of the editor window).
    The result appears in the bottom row of the window : 0.2
    Now replace that one line code by
    (6/5 % 1) == 0.2;
    and press play again. Result ….. false 😉
  • Jack Phillips
    April 11, 2014 at 3:59 pm
    Xavier,
    This works perfectly. I didn’t even know the “switch” statement existed. Must read up on it.
    Thank you very much!
    Jack
