Activity › Forums › Adobe After Effects Expressions › Expression Error – Auto-Scaling text
  • Expression Error – Auto-Scaling text
    Posted by Finn Hitchcock on April 17, 2020 at 4:56 pm
    Hi All,
    I’ve found this expression which uses the scale property to auto scale the text depending on the amount of characters.
    here: https://medium.com/@loranallensmith/auto-scaling-text-size-in-adobe-after-effects-560b07a6cca2
    However, when I applied this an error appeared in line 11.
    Could anyone help me fix this, or point me in the direction of a similar working expression?
    Thanks in advance!
    // This lets us get the width of the textbox containing your content.
    layerWidth = thisLayer.sourceRectAtTime(time).width;
    // This lets us get the width of the current composition.
    compWidth = thisComp.width;
    // This lets you specify a maximum width that text boxes should not exceed. In this example it’s 90%, but you can set it to whatever you need or even map it to a control.
    // Pro-tip: If you have other content in the same horizontal space as your text, remember to account for that content when setting your maximumWidth.
    maximumWidth = compWidth * .9;
    // This calculates the current percentage of the maximum width that the text layer occupies.
    percentageOfMaxWidth = layerWidth / maximumWidth * 100;
    // We subtract that percentage from 100 to find out how much space we can spare. If the text box can grow a bit, leeway is positive. If it needs to shrink, leeway will be negative.
    leeway = 100 — percentageOfMaxWidth;
    // Finally, return an array of [width, height] scale. 100 is the baseline and leeway is how much the layer needs to grow or shrink to fit.
    [100 + leeway, 100 + leeway]
    Finn Hitchcock replied 6 years, 5 months ago 2 Members · 2 Replies
  • Dan Ebberts
    April 17, 2020 at 5:17 pm
    This line:
    has an illegal character in it for the subtract operator. It should be:
    leeway = 100 – percentageOfMaxWidth;
    Dan
  • Finn Hitchcock
    April 17, 2020 at 6:43 pm
    Ahhh thank you!!
    Works perfect 😀
