Activity Forums Adobe After Effects Expressions Expression error around an array popped up out of nowhere
  • Expression error around an array popped up out of nowhere
    Posted by Paul Connors on November 30, 2020 at 4:03 pm
    UPDATE: I’m sorry, it looks like I had a value of “0” for the table1count variable below and when applying the “-1” to that I was getting a negative number for the array lookup and that was causing the error.
    Hello. I had an expression in place that had been working, but now I get a strange error message: “Property or method named ‘-1’ in Class ‘Array’ is missing or does not exist. …” Here is the expression that had been working fine and the all of a sudden started creating this error:
    table1count = parseInt(comp(“MASTER”).layer(“Table1”).text.sourceText,10);
    yArr = [300,185,80,50,0];
    x = 960;
    y = yArr[table1count-1];
    [x,y]
    Thank you very much.
    Paul Connors replied 5 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
