Activity › Forums › Adobe After Effects Expressions › Expression doesn’t work
  • Expression doesn’t work
    Posted by ‘SMR 겜댕 on February 11, 2021 at 11:19 am
    Before asking a question
    We ask for your understanding in advance for the part where you are not proficient in English.
    What I want to ask is this
    Put a keyframe in the A effect and control the speed of the keyframe with the slider control
    And this effect
    I want to be able to turn it on and off with a checkbox
    And when the check box is turned off, I want the keyframe position value set to remain unchanged.
    So I wrote the following expression
    The position value of the keyframe is
    Keep moving
    Oh it doesn’t move or it’s either
    It would be appreciated if you let me know which expression to use
    //This is the first try
    spd =effect(“Slider Control”)(“Slider”);
    accum = 0;
    cb = effect(“Checkbox Control”)(“Checkbox”);
    for (i = timeToFrames(inPoint); i <= timeToFrames(time); i++) {
    if (cb.valueAtTime(framesToTime(i))){
    accum += spd.valueAtTime(framesToTime(i));
    value + accum * thisComp.frameDuration;
    //This is the second attempt
    spd =effect(“slider control”)(“slider”);
    accum = 0;
    cb = effect(“checkbox control”)(“check”);
    if (cb.valueAtTime(framesToTime(i))==true){
    value + accum *nearestKey(thisComp.frameDuration);
    //This expression does not move, but it does not move when the check box is activated.
    //This is the third attempt
    accum = 0;
    //This also failed
    ‘SMR 겜댕 replied 5 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
