Activity Forums Adobe After Effects Expressions Expression doesn’t work with keyframes
  • Expression doesn’t work with keyframes
    Posted by Fernando Duque on September 3, 2024 at 3:08 pm
    Hi, I’ve been searching the forum and I think I know where my problem comes from but I can’t get it to work.
    I’ve made an expression with which I control the rotation of several layers of a precomp with a controller that is in another comp. The expression works great but when I apply keyframes it stops working. I’ve applied the expression to the rotation of the layer:
    comp(“Binny_Front_FULL”).layer(“Brazo L”).transform.rotation
    The precomposition has the time remapped with an expression to be able to select the frame that I want to show at any given time:
    a=thisComp.layer(“Brazo Control L”).effect(“Slider Control”)(“Slider”)
    framesToTime(a)
    I think the problem comes from the remapper. I’ve tried to apply “valueAtTime()” in the rotation expression but I can’t get it to work.
    This is the expression that I’ve applied without success. The rotation works until keyframes are applied to animate:
    C = comp(“Binny_Front_FULL”);
    ctrl = C.layer(“Brazo L”).transform.rotation;
    L = C.layer(thisComp.name);
    ctrl.valueAtTime(time+L.startTime)
    I would appreciate help on this.
    Thanks a lot!
    Fernando Duque replied 2 years ago 3 Members · 6 Replies
  • Sean Cole
    September 3, 2024 at 5:20 pm
    L = C.layer(thisComp.name);<div>
    </div><div>I’m assuming you do in fact have a Layer labelled “Binny_Front_FULL” in your Comp. If not, that would cause non-function. </div>
  • Yoan Boisjoli
    September 3, 2024 at 5:28 pm
    Haven’t had time to test it out but try this instead:
    remappedTime = L.timeRemap.value;
    ctrl.valueAtTime(remappedTime);
  • Fernando Duque
    September 4, 2024 at 7:55 am
    Hi, thanks for your reply.
    I have te remapped layer and the controller inside <b style=”font-family: inherit; font-size: inherit; color: var(–bb-body-text-color);”>“Binny_Front_FULL”. The remapped layer hav an expresion and inside it I have the layers I want to control.
    <b style=”font-family: inherit; font-size: inherit; color: var(–bb-body-text-color);”>Everything works fine til I create a keyframe in the controller
  • Fernando Duque
    September 4, 2024 at 7:59 am
    Hi Yoan, thanks for your reply.
    Your expresion doesn’t fix the problem. Works fiine until I create a keyframe.
  • Yoan Boisjoli
    September 5, 2024 at 2:44 pm
    Hey Fernando, does this help?
    ctrl.valueAtTime(remappedTime + L.startTime);
  • Fernando Duque
    September 10, 2024 at 2:14 pm
    Hi Yoan, the same as befoe.
    I have restarted the configuration and the expressions to avoid to use time remapping and works fine.
    Thanks for your time!
