Activity Forums Adobe After Effects Expressions expression counting from 0% to 100% and start at 0 again.
  • expression counting from 0% to 100% and start at 0 again.
    Posted by Sarah Schela on May 17, 2012 at 3:50 pm
    Hello,
    I looked through the forum for an answer to this question, but haven’t found one.
    So as it is written in the title I am looking for an expression which counts from 0% to 100% and starts at 0% all over to 100% again in a loop.
    I just found this expression saying that the counter runs from 0% to 100% but then decreases to 0% and starts counting upwards to 100% again.
    freq = 1;
    50*(1 – Math.cos(freq*time*Math.PI*2))
    so I believe there must be some kind of “if” like “if the number reaches 100 start at 0 again” or something. but I have not much experience so I hope for some advices!
    Sarah Schela replied 14 years, 2 months ago 3 Members · 4 Replies
  • Kevin Camp
    May 17, 2012 at 4:02 pm
    this should do it. just set the freq value to the loop point.
    freq = 1; // value in seconds
    timeToFrames(time % freq) + “%”
    i also added the % sign in there… if you don’ need that delete the + “%”.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kevin Camp
    May 17, 2012 at 4:09 pm
    i’m sorry, that really doesn’t work quite right… i should test before i post.
    this should do it though:
    freq = 2; // value in seconds
    Math.round(linear(time % freq, 0, freq, 0, 100)) + “%”
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Dan Ebberts
    May 17, 2012 at 4:27 pm
    If you’re just looking for something that counts from 0 to 100 and then starts over, this might work for you:
    rate = 30;
    Math.round((time-inPoint)*rate%101)
    Set the rate to whatever makes sense for your application.
    Dan
  • Sarah Schela
    June 21, 2012 at 1:51 pm
    Thanks so much! really great!
