Activity Forums Adobe After Effects Expressions Expression controls final keyframe value
  • Expression controls final keyframe value
    Posted by Deanna Keogh on August 19, 2021 at 6:49 am
    I’m building a graph template. I’m wanting to animate the y scale of the column shape layer, to which the y is already linked to an expression, which is subsequently linked to a slider. The slider controls the height of the shape/column and I would like to animate it so that no matter what value is placed in the slider, it still animates to the correct value. Basically I need to somehow have the slider value always be the value in last keyframe.
    Any ideas will be greatly appreciated
    My current y expression is as follows:
    x=100;
    y=(thisComp.layer("GRAPH CONTROLLER").effect("Graph")("Column 1"));
    [x,y]
    Many thanks 🙂
    Filip Vandueren replied 5 years ago 2 Members · 1 Reply
  • Filip Vandueren
    August 19, 2021 at 7:42 am
    Keyframe the animation like you would want it for a y-value of 100,
    then use this:
    x=100;
    y=(thisComp.layer("GRAPH CONTROLLER").effect("Graph")("Column 1")) * value[1]/100;
    [x,y];
