Activity Forums Adobe After Effects Expressions expression controle
  • expression controle
    Posted by Peter on November 3, 2005 at 2:16 pm
    Hi there,
    i’m linking the scale property with the pickwickwheel to an Audioamplitude,so that the layer scales with the beat.
    because I wanted it to scale stronger I added *30
    so have this expression written:
    temp = thisComp.layer(“Audioamplitude”).effect(“Linker Kanal”)(“Schieberegler”);
    [temp, temp]*30
    The question:
    How can I manage, that it doesn’t scale to zero when there’s no beat,
    how can i limitize the downscale?
    thx
    Peter
    Dan Ebberts
    replied 20 years, 10 months ago
    2 Members · 3 Replies
  • Dan Ebberts
    November 3, 2005 at 4:03 pm
    The easiest way is probably just to add an offset:
    [temp, temp]*30 + [25,25]
    Where 25 would be the minimum. You’ll have to adjust your multiplier (30) to end up with the same maximum value.
    Dan
  • Peter
    November 3, 2005 at 7:34 pm
    thanx, works totally fine for me.
    and can i smooth the movements, easy ease like?
    peter
  • Dan Ebberts
    November 3, 2005 at 8:33 pm
    You could try the smooth() method like this:
    temp = thisComp.layer(“Audioamplitude”).effect(“Linker Kanal”)(“Schieberegler”).smooth(.2,5,time);
    Dan
