Activity Forums Adobe After Effects Expression Control to work within a comp
  • Expression Control to work within a comp
    Posted by Tiago Cav on May 14, 2015 at 2:45 pm
    I need a external controller, “Layer Control” to work with layers inside of different compositions, because I don’t want to appear as options all the layers in the “Layer Control”. Only specific layers for each “layer Control” are two effects in a “null”, and each has a function. This “null” is the panel what I created.
    Tiago Cav replied 11 years, 4 months ago 2 Members · 2 Replies
  • Nathan Shinholt
    May 14, 2015 at 2:59 pm
    I think I understand what you’re trying to do, but I’m not quite sure.
    Lets say that Comp A has a bunch of layers in it, including Comp B. Above your timeline, you see the tab to open up the Comp B timeline. You can click that tab and drag it down to the bottom docking zone of the Comp A panel. Now you have two separate timeline windows open at once. From there, I believe you can parent specific layers or properties in Comp B to layers or properties in Comp A using the pick-whip. I hope that helps!
  • Tiago Cav
    May 14, 2015 at 5:19 pm
    Amazing!
    Thank you so much! Good idea, smart solution.
    I did it, “Layer Control” is connected to an outer layer and inside comp that “Layer Control” is, now, have only layer that will be used to what I want. Work very well.
