Activity Forums Adobe After Effects expression control time remap
  • expression control time remap
    Posted by Justin Young on January 14, 2012 at 1:20 am
    How do I control the time remap value of an animation of a leg that nested inside a walk cycle?
    I tried this expression on the leg but it doesn’t work:
    comp(“container”).layer(“teen”).effect(“leg1”)(“Slider”)
    It’s like it’s not interpreting the expression as the animation takes place.
    ideas?
    Justin Young replied 14 years, 8 months ago 2 Members · 2 Replies
  • Walter Soyka
    January 14, 2012 at 1:54 am
    [Justin Young] “How do I control the time remap value of an animation of a leg that nested inside a walk cycle?”
    Tough to say because you’ve provided almost no information about how your project is set up — but I’d guess that you need to precomp everything in the leg animation except the time-remapping. In other words, you need to take your animated leg comp, nest that inside a new comp, apply time-remapping to the precomped layer within the new comp, then link it its value back to the container control.
    Walter Soyka
  • Justin Young
    January 14, 2012 at 2:35 am
    I’ll try and explain what I’m doing.
    The guys legs are supposed to grow over time during his walk cycle….so.
    container>walkCycle>legGrowthAnimation
    walkCycle is timeremapped to loop. This is also where the slide control is but change the slide control value from 0 to 100, the legGrowthAnimation isn’t progressing. It just stays stuck on the first frame.
